TIFF2MAP converts 8-bit greyscale uncompressed or LZW encoded TIFF image files to Wayne Stahnke's 3-bit greyscale MAP format.
| First Line | Optionally allows a restricted range of scan lines to be specified. By default the entire file is converted. |
| Last Line +1 | |
| Background | Set to match the background level of the source material so that the roll and any writing on it appear as black in the MAP file. |
| Foreground | Set to match the foreground level of the source material so that holes appear as white in the MAP file. |
| Vertical Resolution | Optionally overrides the value derived from the TIFF file. Useful when Photoshop distorts the declared vertical resolution by applying the horizontal resolution to both axes. |
Background=0, Foreground=255
Background=90, Foreground=255 (default)
TIFF Input
MAP Output (Background=90, Foreground=255)
During conversion the hourglass cursor is displayed while the mouse is within the window.
Current version 1.32, 21 February 2021. TIFF2MAP.ZIP
