MIDI Tempo Fix reclocks MIDI files containing multiple MIDI tempo changes to ones with a new uniform tempo throughout without changing the overall duration.
Alternatively, MIDI files that already have a uniform MIDI tempo may be reclocked with a new tempo, again without changing the overall duration.
Drop the MIDI (type 0 or 1) file(s) into the program window or use the Open button to select a file.
The Output Tempo may either be specified or if left blank the original initial tempo will be used.
The output file (now containing only a single tempo definition) will have a modified filename which includes the new tempo.
Current version 2.00 (13 May 2023): MIDITEMPOFIX.ZIP
After downloading the ZIP file, right click it, select Properties and Unblock it.
